DECT-210 Base Station - MPP Firmware - Not Registered to Control Hub
steigja
Level 3
Level 3
Hello All,
   I'am working with a client who has a DECT-210 Base station that we have upgraded to the MPP 5.0.1 firmware.  However the base station still shows "Status Unavailable" in Control Hub.  There is no indication if it is trying to register.  There is very little documentation I can find on how to configure it to connect to Control Hub.  Should it just try to register?  Anyone else gone through this process?  Thank You!
Jason
Mbarek FADIL
I have the same problem, the base station always shows "Status not available" in Control Hub. it is registered and operational !
Yes, try to register it and wait for Cisco to fix this bug
Jarek Bosacki
Yep, this is correct even if definitely maybe misleading. Instead you will see the status of headsets that would be registered to DECT network.
BR/
