Does the webex calling support loading wallpaper files for 8000 MPP?
ross.sweetman
Customer recently converted from CUCM on premise to WebEx Calling.
In CUCM they had their logo loaded as the Wallpaper.
Is this possible in Webex Calling?
If yes what are the steps to enable?
kgroves42
Level 3
Level 3
Yes, you should be able to do this.
In control Hub go to Calling --> Service Settings. Scroll down to "Configure Default Device Settings"
Select MPP (for the 88XX phones)
Choose Custom Background under Background Image
You can then put the Image in a device accessible Web Server and then put in that address of the URL where the image is stored.
kgroves42
Level 3
Level 3
