Does the WEBEX Room 55 support SNMPv3?
Sykosis
Basically as the title says, does the Room 55 support SNMPv3?  And if so, how do i find out/check what version I'm currently running.  Thank you.
Sykosis
Apologies, It currently running CE9.9.0.  We are looking up upgrade all our WEBEX Room kits and DX's to 9.9.12.
Raheel Zubair
We first need to know what OS version are you using.
