Gray Section on the left
ConnieK
Community Member
With the update the window on the left is now dark gray. Can that be changed It's very difficult to see.
8 Replies 8
anna
Community Member
I am on 42.9.0.23494. I can only get the icon color to change to lighter or the original color when I changed the color scheme to a dark scheme. I prefer the light scheme, which forces the icons back to dark. They are difficult to see - dark icons on the dark blue side bar. I don't like this design decision. Perhaps an enhancement could be to allow people to change the icon colors separately from the color scheme or to return them to light color on the dark background.
ConnieK
Community Member
I agree, I prefer the lighter color scheme, but the only way its easier to
see the icons on left side is to keep the color scheme dark. This came with
the new update. Maybe it will change soon.
dtibbe
You may change the Webex app's theme in the settings if you do not like the color schema.
ConnieK
Community Member
that does not change the window on the left if you use the light theme
ConnieK
Community Member
Can you read my question again and look at the screen shot I attached, I
have put a screen shot in this email as well. Settings does not change the
grayed out area on the left.
##- Plea[image: image.png]
se type your reply above this line -##
Neither in your original post nor in this reply there is an image.
As you said you're mailing your question/reply, maybe embedded images do not work. Please attach it via a browser
ConnieK
Community Member
ConnieK
Community Member
