HDS Micrososft SQL Database Server
guenter.weigl1
Frequent Visitor
Frequent Visitor
we are using Microsoft SQL Server 2016 right now for two HDS Nodes.
The support for SQL Server 016 is ending in June 2026 so we wonder if there are any caveats in upgradeing to SQL 2019.
Action plan would be upgrading the Database from 2016 to 2019 and create a new ISO for the nodes.
Or would it be better if we created a new database?
Hope anybody could shine some light on the issue.
Hello.
Are you talking about upgrading your SQL on UCCE solution?
Kostia -- Helping with Contact Center Solutions
Konstantin Vaksin
