How to auto-generate password for the Cisco Webex meeting using Productivity plugin on MAC
AmaniK
I have installed Cisco Webex Meetings on my MAC High Sierra version 10.13.6. I am experiencing an issue with the Productivity plugin when I want to schedule a meeting,  I am having Outlook auto-generated Window with Room information but with no option for password .. I am using Outlook for MAC (2019) version 16.35 (20030802). Is there any fix so I can be able to auto-generate password for each meeting ?
Best regards
Oruc Akpinar
Hello
to do this you need to download and install on your MacBook Cisco Webex Productivity Tools. and you need to schedule the meetings with this tool. It works MacOs Catalina right now. It probably will work with HighSierra.
You can find bellow more details.
https://help.webex.com/en-us/ncy4rwy/Install-and-Set-Up-Cisco-Webex-Productivity-Tools-for-Mac
regards.
Please rate all posts as helpful, if applicable.
