How to Disable Quick Call
luke123456
I need to disable the Quick call feature as it is conflicting with other programs and frustrating my users.
It seems to be a newer feature of webex "Ctrl + Shift + X"
Is there a setting or regedit to remove this?
tobias.zillmann
Rel: https://community.cisco.com/t5/webex-meetings-and-webex-app/the-new-webex-app-stealing-my-keyboard-shortcut/td-p/4435923
Cisco does not seem to care
For me this would be a major bug. User thinking about closing the client just so they can work normaly.
nvannes
Having the exact same issue. You can disable the CTRL+SHIFT+x in the settings/configuration menu but disabling doesn't make any difference.
Need the hotkey combination in other software Please give the option to change the hotkeys or disable them all.
