Make Sharing Your Computer Audio Option More Visible
maxwell.brown1
Level 2
Level 2
As-is with desktop meetings app the tick box to share your computer audio  is only visible after you select optimize for motion and video. This is not intuitive or user friendly. Present the option at the top level always and force use of optimize for motion and video if you tick the audio share box.
You are likely better off if you where to post this on the Webex feedback portal at https://blog.webex.com/team-collaboration/make-your-voice-heard-with-the-user-community-feedback-portal/amp/
Response Signature
