Synchronize multiple Azure AD's into Webex
JohnNectar94198
Is it possible to integrate/sync 2 separate Azure AD's into Webex? We have part of the business using it's own separate Azure AD, but we would like to investigate the possibility of sync'ing them as one into Webex.
I guess the alternative is to use the connector sync on each side, but it would be nice to avoid this and keep the sync cloud-to-cloud if possible. Any pointers are appreciated!
0 Replies 0
