Is there a way to setup a default for users with their Telephony Privileges? I see that by adding Session Types and then making these new types as defaults it changes the Meeting Privileges. I do not see a way of changing the Telephony Privileges for users as a global default when provisioning new users.
I know I can export the SIteUsers list and then import after I have removed the Telephony Privileges I don't won't them to have.
Also I can manually go in after the users have been added and make the change in Users --> Meeting --> User Privileges, then I can uncheck the different Telephony here.
But Is there a way to globally set this prior to adding a user so that when I add a user using the defaults I setup the correct Telephony Privileges will be assigned?
