ThinClient Versions - Webex Control Hub Troubleshooting
Roray Stewart
Does anyone know what the ThinClient version numbers mean in Control Hub troubleshooting under a participants connection? I haven't been able to track down anything so far to understand them. For example I have two users that have joined via the browser, both on Firefox 81.0 but one shows ThinClient 6.1 & the other ThinClient 10.0. I've also seen multiple other versions for users. Would be good to get an understanding of their meaning particularly if it helps out in a support perspective
Thanks in advance
Roray
Andres Salgado
Hi Roray,
I thought it had to do with the Webex meeting site version. For instance 40.10 would be version 10 which was October https://help.webex.com/en-us/xcwws1/What-s-New-for-the-Latest-Channel-of-Webex-Meetings
I could be wrong since your example displayed different versions for the same browser client at the same time from what I understood. Anyway, I think the important thing to note in terms of support is that the thin client/ browser client was the join method and you can compare if the same behavior occurs with other join methods.
Andres
Response Signature
Hi @Andres Salgado, thanks for the response. I think I came to the conclusion it was related to the operating system being used, so ThinClient 6.1 were Windows 7 users & ThinClient Windows 10.0 users.
Having just taken a look at some live meetings I'm now seeing much better reporting for Thin Client connections in that it now lists it as: Webex Thin Client 41.2.2.575 for example so you can clearly see what version it is along with the operating system and browser. Good to see the improvement there.
tashley
I just had a unwanted participant that appeared in a classroom meeting that connected using a thin client 10.0 . There was not any IP information or any information included other than the client.
Is that a normal situation? All other participants had additional connection information.
Hi Tashley,
Check the following link to add security best practices to the meetings:
https://help.webex.com/en-us/wlvh12/Prevent-Unwanted-People-from-Attending-Your-Meetings
Andres
Response Signature
