UI Extensions Editor in MTR mode
Hi Team,
Currently, I have a Cisco CS-Codec-EQ-K9 plus with Cisco Room Navigator and Crestron control system for in-room controls. Endpoint is configured in MS Teams mode. My concern is whether it is possible to add a UI button in Teams mode? The UI Extension Editor can be done in RoomOS, as far as I know.
Thanks & Regards,
Rajkumar.L
Jonathan Schulenberg
AFAIK this capability doesn’t exist yet and I’m unable to discuss product roadmaps on here as they require an NDA. I’d ask your Cisco Collab PSS/TSA if they have additional info to share.
Has anyone had an update on this?
It's possible - but limited to the control panel that opens when you swipe left from the right edge of the Room Navigator panel or Board/Desk series display. You'll see this as a Button Location option in the UI Extension Editor. MSFT doesn't allow UI extensions within the MTR UI. In-call UI extensions are also possible when RoomOS is joining the call instead of MTR-A. For example, if you join a Webex Meeting or Zoom Meeting from the control panel buttons when the endpoint is dual registered to Webex Control Hub.
