Update Failure
Pepco Rob
Community Member
Many of our employees have been having issues with blank boxes popping up when calls come in. I went to look at everyone's version only to find out that some of them have not been updated. When I click the "Check for updates" button, it states that something went wrong and try giving it another shot. Unfortunately, that is the same message I continue to get. Has anyone experienced this issue? Does anyone have a suggestion on how to correct this error?
Jeff-PCC
Visitor
Did you get the issue resolved?
If not, I wonder if it is related to the "Webex Aware" software update that has been giving incorrect devices statuses. A device will be registered and fully operational (make/receive calls), but Control Hub shows the device as 'Offline'.
If it is 'Offline' you cannot perform any administration on it as CH thinks it is not connected.
sameh.shouhdy
Frequent Visitor
Frequent Visitor
Hello
Do you have screenshot for the issue .. ?
