Webex Calling Template Limitation
anthony.lotito1
Frequent Visitor
Frequent Visitor
I am adding 117 new locations to my Org within Webex Calling. When I try to add the Locations into a Calling Template, the drop down list will not show all the locations so I am unable to add them to the Calling Template. Looking for some advice on how to get the remaining 12 of the 117 locations added.
dtibbe
Do the locations also not appear in the list if you directly search for them in the list?
I can manually enter the location name and it does show. There needs to be a way to bulk this into the a calling template. The drop list method is fine if you only have a few locations to add. I will eventually have about around 300 locations on the multi tenant and 40 on a dedicated instance.
Yeah, that doesn't sound like fun..
I think there is currently no bulk assignment from the location side and no API endpoint for that either.
I'd suggest opening a product enhancement idea via AHA https://ciscocollabcustomer.ideas.aha.io/ and also talk to your AM team.
