Bookmark
Subscribe
13924
Webex .deb not working on Linux Mint (Debian Edition)
Ruudiculus
Hi all,
I just heard the great news that Linux-version of the Webex client is out and wanted to give it a try.
The .deb package installs fine (using gdebi), but when running the application it terminates after a short while, without showing any GUI nor any logging.
Are more people experiencing this?
I'm running Linux Mint Debian Edition (a.k.a. LMDE 4 Debbie, Cinnamon version 4.8.6, kernel version 4.19.0-16-amd64). More info on this flavor of Linux, here: https://linuxmint.com/download_lmde.php
The command registered in the menu is:
/opt/Webex/bin/CiscoCollabHost %U
While the Webex.deb ships a load of libraries, the specific 'CiscoCollabHost' command doesn't seem to require them, according to 'ldd':
ldd CiscoCollabHost
linux-vdso.so.1 (0x00007ffed4ec9000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f0cee76f000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f0cee74e000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f0cee58d000)
/lib64/ld-linux-x86-64.so.2 (0x00007f0cee999000)
(The two CiscoCollabHostCef* variants do however).
Maybe the problem has to do with any Qt-libraries my system is lacking... (which 'ldd' would strangely not list)?
I pretty much ruled out permission issues, since the binary IS executable, and since changing ownership of the whole directory from 'root' to [user] didn't help either.
Without proper application logging it's hard to tell...
akai4869
I had the same exact issue with Debian 10 with kernel version 4.19.0-16
I also tried to execute the bin CiscoCollabHostCef from terminal  and got this output:
No usable sandbox! Update your kernel or see https://chromium.googlesource.com/chromium/src/+/master/docs/linux/suid_sandbox_development.md for more information on developing with the SUID sandbox. If you want to live dangerously and need an immediate workaround, you can try using --no-sandbox.
Since this talked about kernel version, I thought that switching to a more updated Kernel could be a solution. And... now it works!
I'm currently using the 5.12-3.1 version but as far as I know, at least from 5.10 should work
I hope this will solve your problem as well
17 Replies 17
m-reuter
Came here through searching. Im on Ubunto 24.04
Had trouble to install Webex, see this thread.
https://community.cisco.com/t5/webex-meetings-and-webex-app/webex-needs-apparmor-profile-for-ubuntu-24-04/m-p/5077364/thread-id/11311
But now its installed, but not starting. Very frustating Cisco
terstegge
I had the same issue with Linux Mint 20.3 (Una). WebEx was not starting after upgrading to the latest version...
I upgraded the linux kernel to 5.15.0-52-generic and still WebEx did NOT work. But I finally found out how to solve this issue.
After upgrading the kernel, a manual start of CiscoCollabHostCef still had the sandbox error (the other binaries were still silent):
/opt/Webex/bin$ ./CiscoCollabHostCef
[1108/100619.487827:FATAL:zygote_host_impl_linux.cc(117)] No usable sandbox! Update your kernel or see https://chromium.googlesource.com/chromium/src/+/main/docs/linux/suid_sandbox_development.md for more information on developing with the SUID sandbox. If you want to live dangerously and need an immediate workaround, you can try using --no-sandbox.
Trace/Breakpoint ausgelöst (Speicherabzug geschrieben)
 So according to another post I did:
sudo sysctl kernel.unprivileged_userns_clone=1
service procps restart
After that, WebEx would still NOT start. Since the WebEx installation comes with lots of shared libraries (for me they are located in /opt/WebEx/lib and /opt/WebEx/bin, I set LD_LIBRAY_PATH:
export LD_LIBRARY_PATH=/opt/Webex/lib/:/opt/Webex/bin
 After that, WebEx started again! So to sum up, my proposal is to:
  • Update the kernel
  • Set the kernel.unprivileged_userns_clone property in the kernel
  • Write a small srcipt, which will set LD_LIBRARY_PATH before starting CiscoCollabHost
akai4869
For those not wanting to upgrade the kernel to solve this issue, an alternative solution would be to enable the unprivileged user using the following command. Please be aware of any security consequences this might have for your system.
Hi akai4869,
I can happily confirm that upgrading from kernel 4.19.x to kernel 5.10 solves the issue!
Luckily the Linux Mint Debian Edition (LMDE) also provides a backported 5.10 by default, so I only had to install:
linux-headers-5.10.0-0.bpo.4-amd64
linux-image-5.10.0-0.bpo.4-amd64
Happy that it works!!
And thanks for your pointer!
pdemonaco
I built a Gentoo ebuild for this using the RPM distribution and I'm running into the same issue. Does anyone know if the launcher supports additional arguments so we can get some error messages?
Here's the ebuild for reference: https://github.com/pdemonaco/overlay/blob/master/net-im/webex/webex-41.5.0.ebuild
(obviously the license isn't actually MIT, but I was too lazy to find the Cisco EULA for Webex during testing)
My problem might be related to the lack of systemd on my system, however, I'm seeing the exact same behavior.
The rpm version of the package doesn't reference QT in it's dependencies - perhaps that's unique to the deb.
It was in my colleague's attempt to convert the deb to an arch-package which resulted in the arch-package requiring Qt-deps. So it may well be introduced by the converter script he used for that.
Ruudiculus
Meanwhile I opened a support case. To be continued...
A senior engineer handled my support case and was able to reproduce the problem on both LMDE and Debian. Het also pointed me to a document which states that Webex support is currently limited to Ubuntu 18.04 and Ubuntu 20.04 as well as CentOS / RHEL 8.2 and 8.3:
"As of this moment only Ubuntu 18.04 and Ubuntu 20.04 as well as CentOS / RHEL 8.2 and 8.3 are supported.
You can subscribe to this document https://help.webex.com/en-us/9vstcdb/Webex-for-Linux#Cisco_Reference.dita_86ea12dd-8b6c-4c57-bcdf-63878239b931 for updates to see if Debian gets to be supported in the future."
So, unfortunately, he couldn't help me further with this at this point in time. In the evaluation of the support case I've pointed out that according to distrowatch.com Debian's popularity is almost just as vast as that of Ubuntu, which is a good argument to do support Debian. The support case has been closed, but hopefully support for Debian is added to Webex soon.
If I find time to play around with Webex on Debian and manage to run it properly, I'll post it here.
In Debian 10 Buster, current stable version, the same happens. The Webex.deb package installs without issue, but when you launch the app this don't works. I try ubuntu 20.04 LTS and works!
Best Regards,
I have exactly the same problems. The installation is without issue. But the app doesn't start with Debian 10.
With Ubuntu 20.04 LTS it works fine!
Are there any known solutions to the problem?
Kind regards,
Same here (Debian 10 Buster). With Manjaro (Cinnamon or KDE, using the package "webex-bin" from AUR) it works!
Ruudiculus
In subsequent runs the executable finally outputs some logging:
Wx: X error received: type 0, serial 9, error_code 3, request_code 12, minor_code 0
Wx: X error received: type 0, serial 10, error_code 3, request_code 8, minor_code 0
I have no clue whether this might be a WxWidgets-error. WxWidgets is a facade to Qt and Gtk and Linux Mint's Cinnamon is Gtk, so this might well be GUI-errors (maybe even from the X windowing or wayland system).
I also noticed that:
  • folders Webex and WebexLauncher (with logs) are created in ~/.local/share.
  • The executable shows up as two processes, one of which is a zombie-process.
Webex/hostlogs/webexhost.txt:
2021-05-10 14:06:53 Attempting to use VersionSelector from Launcher directory
2021-05-10 14:06:53 Failed to get VersionSelector from Launcher directory, using installed VersionSelector instead
2021-05-10 14:06:53 ACTION Calling the entry point.
2021-05-10 14:06:53 ... BEFORE ENTRY POINT ...
2021-05-10 14:07:03 ... AFTER ENTRY POINT ...
2021-05-10 14:07:03 ACTION Exited from the entry point.
2021-05-10 14:07:03 Finished successfully, exiting.
Webex/hostlogs/webexhost-libWebexAppLoader.txt:
2021-05-10 14:06:53 ... AFTER ENTRY POINT ...
2021-05-10 14:06:53 ACTION Exited from the entry point.
2021-05-10 14:06:53 Finished successfully, exiting.
WebexLauncher/webexlauncher.txt:
2021-05-10T12:06:53.697Z Webex launcher started, location: /opt/Webex/bin/CiscoCollabHost, launcher version: 41.5.0.18787
2021-05-10T12:06:53.697Z starting version selector in /home/ruud/.local/share/WebexLauncher
2021-05-10T12:06:53.697Z Found an original installation directory at: /opt/Webex/bin/
*** Creating a directory with name: /opt/Webex/bin/
Executable: [/opt/Webex/bin/CiscoCollabHost], Version: 41.5.0.18787
2021-05-10T12:06:53.698Z Current dir: /opt/Webex/bin
2021-05-10T12:06:53.698Z The directory /opt/Webex/bin/ is being compared to /opt/Webex/bin/
2021-05-10T12:06:53.698Z Result: true
2021-05-10T12:06:53.698Z The directory /opt/Webex/bin/ already exists, skipping.
2021-05-10T12:06:53.698Z Found 1 possible locations for Webex installations.
2021-05-10T12:06:53.698Z Directory: /opt/Webex/bin/; integrityOk: 1; containsBinary: 1
2021-05-10T12:06:53.698Z Examining location /opt/Webex/bin/
2021-05-10T12:06:53.698Z Location contains Webex, is intact and it's a potential candidate.
2021-05-10T12:06:53.698Z Considering /opt/Webex/bin/ the best candidate so far, because 41.5.0.18787 is greater than 0.0.0.0
2021-05-10T12:06:53.698Z ******* ALL DIRECTORIES  ******
2021-05-10T12:06:53.698Z Explicitly marked as non-removable: /opt/Webex/bin/
2021-05-10T12:06:53.698Z Marked 0 total directories for deletion.
2021-05-10T12:07:03.699Z Exiting launcher.
When run within 'gdb', not much extra information is gained:
(gdb) run
Starting program: /opt/Webex/bin/CiscoCollabHost
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[Detaching after fork from child process 7611]
[Inferior 1 (process 7605) exited normally]
(gdb)
i had the same problem, i found a way to make it work.
1) start webex in the browser. trough web.webex.com
2)start a meeting
3)click of the "more", button , and then click on "start webex desktop app".
after that Webex is starting normally, but is the only way it works, using xdg-open.
but i can't figure out the exact command chrome is using to launch webex.
Im on Ubuntu 24.04
After the journey how to install webex, I still can not start it.
But this way works on Ubuntu 24.04 for me too
WTF Cisco
A colleague of mine (using arch-linux) confirmed that the .deb package (once converted to arch-package) installs and works just fine. He's using KDE however and therefore his Webex-installation relies on Qt. Since Linux Mint Cinnamon uses Gtk, my installation of Webex has other dependencies. While I do recognize pango and cairo, I would also expect actual Gtk dependencies, but they're not (see attached screenshot).
I wonder if someone has ever tested this Webex.deb on a Debian/Ubuntu GNOME system.
