11-06-2019 12:24 PM
Webex Meetings (the app that launches after you join the meeting from the calendar invite) version 39.9.3.125 screen sharing appears to be broken in MacOS 10.15.1, if you share the entire screen the remote viewer just sees the desktop background, and if you share a specific window (terminal in this case) the user reported a similar thing.
The same version on MacOS 10.14.6 works fine.
11-06-2019 01:53 PM
Curious, did you set the permission to allow for Screen Recording in Security & Privacy ? I had the same issue this morning and once I enabled it, and launched another meeting it works.
Thank you,
Vasanth
11-07-2019 10:52 AM
