Webex Pin number & Cloud Conference room question.
qwejkl123
Hello.
Here's a question about webex.
Will the Webex host pin number be changed?
Is there a period of change?
Also, can you detect if you are using the cloud conference room in real time?
Please reply.
Vaijanath Sonvane
As a Webex Account Host, you can login to your Webex Site and change your PIN under Preferences. There is no expiry date for PIN.
For your the question, can you explain in more detail about what you are looking.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
