07-18-2022 10:02 AM
We have several conference rooms with Room Kit Mini and Flip 2 65" screen. I now need to upgrade a room with an 85" screen. I can't find any docs detailing compatibility for the 85" Samsung Flip models. There are 3: Flip 2 WM85R (which I assume works being a Flip 2), Flip 3 WM85A (which should work since the WM75A is compatible), and Flip Pro WM85B
07-18-2022 11:28 AM
Hi Matt,
As per Cisco and Samsung documentation, I have seen that Webex Room Kit Mini is supported only on Samsung Flip 55" and 65".
https://image-us.samsung.com/SamsungUS/samsungbusiness/pdfs/WEBEXONFLIPBRO-APR20T.pdf
I would recommend to open a case with Cisco or Samsung before you make any decision.
07-18-2022 03:14 PM
Hi Vailanath,
That doc predates the release of the 75" and 85" models. Samsung says in the Flip 3 75" (WM75A) documentation that it is certified and has installation instructions. https://downloadcenter.samsung.com/content/UM/202107/20210718035040001/BN81-21027B-03_WEB_WMA%2075_NA%20ZB_L03_210716.0.zip
