Webex Teams avatar sync/cache problem
I have a sync problem with the Webex Teams avatars/profile pictures.
Our Webex Teams is synced with Cisco Directory Connector, which is synced with our Microsoft domain.
On the Directory Connector, the avatar is displayed correctly (Configuration > Avatar > Get user's avatar).
On the Webex control hub and teams application, it are still the old avatars that are displayed, so it seems like there is a cache issue somewhere.
I've tried deleting the cache (C:\Program Files (x86)\Cisco Systems\Cisco Directory Connector\Plugins\DirSyncPluginAvatar.dll-cache.bin) and performing a dry run sync and a full sync, but still the old avatars remain on the Webex control hub and teams application.
Anyone any ideas on how to resolve this issue?
Thanks in advance.
I suggest opening a TAC case at this point. Something must be hung up on the backend.
Jonathan Schulenberg
How much time has passed since you began syncing new avatar photos with a full sync? I have seen it take a days to refresh caches client-side. I want to say WCH updated within 24hours though.
Does the new photo appear if you login to https://settings.webex.com/main/profile?
Hi Jonathan,
Thank you for your reply.
It has been a week now, so normally everything should be synced.
The new photo does not appear on https://settings.webex.com/main/profile
I also tried deactivating the sync between WCH and the Directory Connector, reinstalling the Connector and syncing everything again, but still no luck.
