Problem in Lan connectivity
ManojKumar37257
Frequent Visitor
Frequent Visitor
Problem in webex kit !!!!!!!!!!
Having problem  in webex calling .  Customer is having problem when trying to connect through lan , while connecting to Wifi services are working properly. I am hereby attaching snaps for your reference Kindly help to isolate the issue .
Mike_Brezicky
A quick test from the lan you can try is from any computer on the same network - go to https://mediatest.webex.com and it will parse through all services to see what failed or succeeded.
balaji.bandi
Need More information :
how is your network environment ? and you need to check below components :
1. do you have proxy in the enviroment : - so check is there any deny logs ?
2. Do you have Firewall  - so check it was allowed ACL for the webex IP address range allowed list.
When you mentioned Wifi working  ? is this same place or Public wifi ?
BB
