WxCC Variable Functionality
farce0710
Community Member
I am in the middle of building several different flows, where I would love to use some set of new variables I want to create, however I am struggling trying to find out if there is a possible way to use the same variable on all my flows or do I have to create the same variable on each flow I build.
I can't use the Global variables because the value assigned to them will be different.
b.winter
If you can't use Global variables, then there is no other option available.
Because Global variables are the only variables, that are above / outside the flows.
But, to me, the type of variable that you need,sounds more like a flow variable.
