10-30-2025 12:39 PM
Our customer uses Amazon Connect, which gives them the ability to record their outbound calling,With the mandated shift to webex they lost the ability.
Can they still use Amazon Connect with Webex calling with some integration
Solved! Go to Solution.
10-30-2025 03:45 PM
Webex Calling and Webex Contact Center both have call recording capabilities so I don’t understand what they lost. Running both products simultaneously also sounds expensive and complicated.
Anyway, the Local Gateway feature of Webex Calling allows a SIP SBC - such as vCUBE running in AWS - to build a trunk to other SIP-capable telephony platforms. The CUBE interoperability page even includes an example for Amazon Connect. Be aware that the current iteration of this feature does not allow transit routing through WxC-MT to the PSTN, only internal calls between the two platforms. We cannot discuss roadmap on the public forums so if that’s an issue you’ll want to ask about future plans internally.
10-30-2025 03:45 PM
