Biamp tesira forté VT4
sweeneyjoe
does anyone know if the Biamp tesira forté VT4    sip conf system is compatible with webex calling?
dtibbe
Nope, it is not supported. The list of supported devices is here: https://help.webex.com/qkwt4j/
You may try claiming it is a supported 3rd party device, grab the sip credentials and see if it is working. But it would be a non-suppoted solution, no help from TAC etc.
ok thanks
Did you have any luck doing VOIP or did you end up just using an ATA?  I feel like it possible since Biamp is fairly capable when it comes to VOIP.
