How to configure cellphone # as outgoing Caller ID using Android phone
rafi-d
How can I set up the caller ID NOT to be my assigned office Webex Calling number, but as my own cellphone number (the one the call is being made with) ? The idea is that people will be able to identify me with my already known cellular number.
Rafi
rafi-d
Disappointing. It should really be possible to set the caller ID on any cellphone to your OWN phone # ...
rafi-d
Jitendra :
I have been there,  as far as I (and my support team) understand, the hub will not allow setting the phisical cell number you are using as CLID. Are we missing anything?
dtibbe:
> You cannot specify an abritrary number.
The physical cell # is not arbitrary, it is yours... Webex setting  I am too novice to follow you, what is LGW, and the "magic" you refer too? Can you be more specific? If I am using Call through mode instead of "Use VoIP", it is shown under "This Phone Number" .
Any help/steps will be appreciated.
dtibbe
You may just specify the CLID as a number from your location. You cannot specify an abritrary number.
If you're using a LGW, you may do there some magic by manipulating the PAI or so..
See also https://help.webex.com/nh3x9zt/
