Restrictrion Call on Webex Calling via Local Gateway
maheza firz
Currently on my Webex, can call over PSTN via Local Gateway >> CUCM. For restriction calls cannot be done by CUCM because CUCM only forwards calls from webex via local gateway to PSTN. therefore for restriction calls I do in webex, each user will have a different call privilege. When i go to outgoing call permission, the setup only this :
What do I need to do if I want to give a certain access call to one of the extension numbers like in CUCM there is a CSS that handles restriction calls?
maheza firz
How do I configure call privilege like CSS in CUCM on Webex Calling?
My scenario is:
  • I have Webex Calling user with Webex Calling Professional Licenses enable.
  • I have integrate Webex Cloud to Local Gateway with Registration base mode.
  • I want to give some user capability to call to local or national or international and some others not.
  • What configuration can be done to make it possible?
Webex Cloud → Local Gateway → Router VG → PSTN
