Stand Alone Phones for Extension Mobility in Webex Control Hub
DanB03UK
My customer wishes to have 10 stand alone 6821 desk phones that have a virtual line with hotelling enabled so that users that are sharing desks can log in and out of.
Now I know how to build and assign a virtual line, set a device and a user up with hotelling, its more so how to register a phone that is not assigned to a user.
A work space it seems that you can only add one device to, but in theory I need 10. Is it a case that i need to create a work space per phone or is there a way of registering multiple devices that share the same virtual line as its primary number (which wont be used to call out or into
Dan
Vaijanath Sonvane
Hi @DanB03UK,
The workspace supports only one device. In your case, you need to create 10 workspaces for 10 devices.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Vaijanath Sonvane
Hi @DanB03UK,
Sorry for late response, many thanks for your reply
