WebEx
pyoung245
Community Member
On a call with WebEx after 5-20 min I get some tones, and then my call drops.  Any body knows why?
dtibbe
Just to be sure: You're on Webex Calling, not Calls on Webex, right?
Is that the same behavior if you get called or if you call someone else? Is it for internal and external calls as well? Which PSTN option are you using?
pyoung245
Community Member
Yes on WebEx calling. It happens when I make a call and receive a call.  Also now when I make a cal it does no show in All Calls.
