Error - Sender Id is not configured
aniket-raut
Hello Folks,
I am doing Webex Connect Flows Lab. I have created Demo Account.
I am not able to Make Flow Live. Getting Error "Sender Id is not configured." in SMS Channel.
In SMS Channel Settings From Number is selected as "CONNCT".
In Number configuration I can see CONNECT without any Sender ID.
5 Replies 5
Arindam Dhar
Hi @aniket-raut ,
We have raised this issue with our technical support team. Will get back with more information once the team has investigated it.
Arindam
Hi @Arindam Dhar Any Update from Technical Support Team.
Hi @aniket-raut ,
Please let us know if you are still facing this issue. If you are still facing it, please share the last 4 digits of your registered mobile number so that we can investigate further.
Arindam
Hi @aniket-raut ,
Our technical team has found the sender ID - CONNCT to be working in their tests. Can you retry and confirm if you still face the issue. If the issue persists, kindly share the last 4 digits of your registered phone number so that we can investigate further.
Hi @aniket-raut ,
Team is investigating the issue currently and is yet to get back with an update.
Arindam
