Showing results forĀ
Search instead forĀ
Did you mean:Ā
Is it possible to call a VXML application using a task from webex conn
SurbhiGarg09154
Is it possible to call a VXML application using a task from webex connect?
Flow is like
Email flow from webex connect --> CCE create task node -->CCE DN --> CCE calltype --> ICM script --> Run external script node to call VXML application ( which will have dialer import API to make outbound call)
0 Replies 0
