Bulk workspace creation preparation
brunokcisco
We do plan to migrate hundred devices from existing TMS & VCS on-premise environment into full WebEx cloud control hub managed solution. Device migration as self we do plan to do one by one in specific timeslots over a period of time. To prepare control hub surrounding we would like to create all the needed workspaces with their specifications in advance.
How to create multiple workspaces in ones?   via CSV or other?
mvondee
In the Control hub, navigate to the Devices >> Add devices  >> Multiple Cisco IP phones >> from the drop-down, select Add device ample template. Create a CSV file with all your devices using the template as a guide. Once you have your CSV file created, upload it to the bulk Add Devices page, this is the same page you downloaded the template.
