I want to block users from accessing the settings button on the phones so that they should not change the network settings, etc. ¿Can this be done? We have model phones: 7821, 7832 and 8845.
My DX80 does not have bluetooth or any wireless connection. The person who uses the device does not have room for it on their desk so they have positioned it across the room. Is there anyway that I can give them the ability to mute/unmute from their ...
Brand new out of the box system. Room navigator will not communicate with media server. IP address of media bar is entered however the "Connecting" indicator continues. Bottom of screen shows "Could not connect to target system. Wrong target syst...
Where is my website located?
Over the past 2 hours, we have noticed that our webex calling registered codecs (variety of models) in different locations across the world are not negotiating an audio codec when joining a meeting. The Audio codec on the call information says "Not A...
Hello Hive Mind, I ordered a CP-7832-3PCC-K9 and was unsuccessful in adding it to my Organization via CH. I performed a factory reset (several times), and changed the profile rule to http://cloudupgrader.webex.com/Cisco/Upgrade/$MAU/$SWVER/$PSN.xml. ...
Hi,I have number of rooms integrated into Exchange Online through the Webex Hybrid calendar. This displays the meeting details and join button at the time of the meeting or prior. Just wondering if it's possible to disable the meeting details and joi...
Why would we be having issues with calls on a DX80 cloud registered to some of our on prem devices that should have FECC. The two devices I tested with were on CE 9.14.3 SX20 and CE 9.13.0 on MX300 G2. Any thoughts why or is this a limitation on co...
Having an issue with HS 730 headset. The volume is SUPER low, barely hearable although the volume is adjusted to max. There is no support contract for this so I can't contact Cisco directly regarding this. Any ideas? This happens on bluethooth, wired...
Hi Team, Can we use a file with the whiteboard?We use room kit mini, and we would like to work on images, excel/word files with the whiteboard function. Is this possible? Thank you
This was highlighted in the past, but now doesn't seem to be talked about.Being able to easily join Zoom (and Teams) meetings directly in rooms with Webex Devices is important. I know we can do "USB passthrough," but that is a nice secondary option...
for a particular remote location, WebEx devices showing offline in WebEx Control Hub, but I am able to launch its Web Portal and do the device changes. Rebooting the device does not resolve the problem. What could be the problem, can someone help ple...
I have one of those Cisco Webex Deck Pro. If there any other way to shut off it's camera beside closing the little shutter it has?
We want to know if Webex Meetings are can be closed captioned live and shared on Facebook with captioning? We don't want to enter closed captioning after the meeting.
Is there a way to turn off the on screen message and sound for when a source connects and disconnects? Specifically for the Room Kit codecs
| Subject | Author | Posted |
| 04-21-2026 01:17 PM | ||
| 04-21-2026 01:09 PM | ||
| 04-09-2026 05:31 AM | ||
| 02-18-2026 12:18 PM | ||
| 01-24-2026 06:40 AM |
