Cisco Room audio default mode even after selecting the noise removal
basil-mathew
In Cisco Room devices default value for noise removal is off. If we enable noise removal option and then after one meeting or call this setting goes to default mode again, should not.
Why is it so ? Is there a way to keep the noise removal option active all time
PJMack
Level 7
Level 7
It definitely should not do this - I manage thousands of Cisco video endpoints, it does not do this in our environment. Unless you have a macro that's running after call termination, but if you have one that's doing this definitely change it.
How this can be fixed in that case ?
