Cisco Webex Desk Pro - USB C connection issue.
norman.lim
I just received two units of Cisco Webex Desk Pro from my HQ.
I have issue with the USB C connection with one of them.
When I connect the USB C cable to a Windows 10 laptop, it doesn't detect any devices of the Cisco Webex Desk Pro.
I tried to swap the cable between both Desk Pro, but both cable give same result, could not detect any devices of the Cisco Webex Desk Pro. I received message "The last usb DEVICE you connected to this computer malfunctioned, and Windows does not recognize it".
When I connect using HDMI cable, it could detect the monitor and speakers of the Desk Pro.
I have no issue with the other unit, when I plugged the USB C cable to my Windows 10 laptop, it detected the Camera, Microphone, Speaker and Monitor of the Desk Pro.
Please let me know how to solved this issue.
8 Replies 8
patrick blazy
I've got the same problem on Mac and Windows, already changed the cable, reboot all the devices. Could it be a physical issue and how to fix it ?
@patrick blazy wrote:
I've got the same problem on Market-Promocode and Windows, already changed the cable, reboot all the devices. Could it be a physical issue and how to fix it ?
What version of Cisco are you using?
I've just checked the update this morning using 10.19.1.5
I think it's a physical issue, I've open a call to Cisco about that
norman.lim
I have two units of Desk Pro. Both units have updated RoomOS version.
One unit is working well.
The other unit has issue with the USB-C connection.
I tried to swap the USB-C cable but it does not help.
I just opened this case to Cisco Case Manager website.
Thanks for your response.
Check if there is any security control application that may block USB ports.
norman.lim
No. I don't have Codec Pro. I have only Cisco Webex Desk Pro.
I got confused,
Both working and non working are of same firmware version ?
could you please try a different USB-C cable.
if Smartnet available I would suggest to raise an RMA.
Response Signature
Are you trying to Use Cs kit Pro as you Camera and Mic for a meeting on your windows machine making use of  Usb Passthrough. if yes AFAIK cs kit pro doesn’t  support that. USB passthrough is support only on Deskpro and CS kit MINI.
Response Signature
