06-17-2024 09:14 AM
I have a Webex 55 (CS BRD 55SNR K9 TAA V01) and a Webex Room Navigator (TTCS-15). The Webex 55 appears to only have one Ethernet port as does the TTCS-15. How do I connect the navigator to the codec, while also being able to connect the codec to the network. It appears most other 55 series codecs have dual ethernet ports, one of which is dedicated for the navigator. Any advice would be helpful.
06-24-2024 09:51 PM
The earlier "Board" devices were designed to be used as touch screen devices, so do not need a Room Navigator to operate.
As other have said, you can pair a touch controller to a Webex Board, but not all Boards support connection of a Navigator - some of the older ones only support the Touch 10.
See Connecting a touch controller to Boards and Room Series devices (webex.com)
Please remember to mark helpful responses and to set your question as answered if appropriate.
06-17-2024 09:24 AM
You will want to make certain both the Board 55s and the Room Navigator are on the same local network. Once they are both powered on you will use the IP address of the Board 55s to connect the Room Navigator to the Board 55s.
06-17-2024 09:26 AM
Here is also the setup guide for the Room Navigator. You may find it of use as it includes a step by step guide. Setup a Room Navigator - Cisco
