05-18-2023 06:10 AM
CS-KITPLUS-K9并没有RS232串行接口,如何与第三方中控主机的RS232串口对接,是通过在Codec Plus上的USB接口插USB转RS232转接线来实现吗?
另外请专家老师告知下串口代码表,谢谢!!!
Solved! Go to Solution.
05-24-2023 05:50 PM
You can connect a USB (Type A) to serial (D-sub 9) adapter. Most USB to serial should work but Cisco recommends the UC232R-10 USB to RS232 (FTDI) adapter for best compatibility.
Please remember to mark helpful responses and to set your question as answered if appropriate.
05-24-2023 05:50 PM
05-24-2023 06:11 PM
Thank you for your reply! Can you help me to provide a code list for the central control instructions?
Detailed instruction code is required to write instructions into our central control host.
