Headset 522 firmware not working
Charlo
I am a technician and some people in the company have the same problem with their cisco headset 522. The red lights on the headset are ON. The problem occured after they did the latest firmware update. The device isn't working at all.
My os is in french, sorry for the inconvenience
Here are the things I already tried :
  • I can't update update the driver on the cisco accessory hub because the firwmare version isn't supported
  • I tried to uninstall the device and reinstall it
  • I tried to update the firware
Here are some other information :
  • In the headset properties, it says that the device cannot start
  • In the event log, it says that the device cannot be configured (wdma_usb.inf)
  • In the settings, it says that there are some driver error
  • When the headset is connected with the aux cable (without the usb dongle that is in the image below), the headset's speakers work, but not the microphone. So, i think that the problem is the usb dongle.
Adam Pawlowski
I was just handed a 530 with this problem
While I'm not sure why or how, I plugged it in while holding the "call" button down. The button lit up, the device connected to the system, and Webex said it needed an update. After that and restarting the Webex app, it seems to be working fine again.
Charlo
After some research, i found out that the problem is the firmware in the headsets. I think that they are corrupted. The thing is, I can't reinstall them.
Webex doesn't propose new update to me because the latest firmwares are installed.
For some reason, the Cisco Accessory Tool doesn't let me install the drivers...
I don't know what to do...
