Kit plus - HDMI input as extended desktop
jodonnard
Hi all,
basic question, is that possible to use HDMI input (H & I in Cisco Room Kit Plus Installation Guide) with one desktop, in like extended desktop ?
thanks by advance
Matt_W
Level 3
Level 3
Connecting hard wired to the HDMI inputs on any of the room systems will be seen as a display output by a computer.  So quick answer is yes, it can work with extended desktop.  Note: when starting or ending a call you will need to reshare the content to the displays.
