Webex DeskPro with Surface Pro 9 via USBC connected flickers
Mariam Wagih
I have a surface pro 9 5G connected to a surface dock to Desk Pro via USB-C. When connected to the surface pro 9 it flickers black screen then no signal till I restart the deskpro to have connected through the USBC
Mariam Wagih
We are using the Cisco 'USBC cable and we tried with 2 cables. but the same issue and when connecting directly to the Surface Pro 9 5G, it worked well at the beginning and then it flickers. do you think it is a compatibility issue between the Surface Pro 9 and the Desk Pro?
I've seen this happen when using some 3rd party USB-C cables.   Not all cables are equal, and the quality of the cable and ensuring it has all the required pins connected, makes a huge difference.   Use the cable that came with the DeskPro if you haven't tried it already.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
