No display of a screenshare with Cisco Webex Codec Plus
naerod
My company uses a Cisco Webex Codec Plus, and I can't manage to show any kind of screen share on the main screen of the Cisco Webex Codec Plus.
We are using COMU to create conferences.
I tried using all the buttons on the remote dashboard, but I couldn't manage to show it bigger than the small camera of myself.
I feel like it's not possible, but if it is, does any of you knows how ?
Best regards
Dorian JULIEN
PJMack
Level 7
Level 7
Do you have multiple monitors connected to the codec? If so the codec doesn't send content to the first screen when in a call, only the second or third, depending on how many you have. If you want the split screen on the primary, configure the codec so it behaves as if there is only one monitor and it will do what you're looking for.
