Official Recommendation for Combining Rooms with Cisco Room Bar EQ
Latnok007
Hello Cisco Community,
I am seeking an official recommendation or advice from Cisco that can be supported by a TAC case in case of failure. I have three rooms, each measuring 10m x 4m, separated by collapsible partitions. Two rooms are equipped with a Cisco Room Bar Pro and Table Mics Pro and 1 room equipped with Room EQ. I would like to use these rooms in a combined mode, meaning all three rooms would function as one unique room.
Could you please provide any official solutions proposed by Cisco for this setup? Specifically, I am looking for guidance on:
  1. How to configure the Cisco Room Bar Pro and Room EQ and Table Mics Pro(or ceiling mics pro)  to work seamlessly in a combined room setup.
  2. Any best practices or recommendations for ensuring optimal audio and video quality in this combined mode.
  3. Any additional equipment or configurations required to support this setup.
Thank you for your assistance.
Latnok007
@Kathy N.  thank you so much for your response and advise.
Kathy N.
@Latnok007,
We are also working on setting up an area that has collapsible partitions so they can work independently or as a large room.   I am working with my Cisco team and an independent AV installer to integrate the systems but it does require external equipment, like Crestron, to "manage" the devices.  Since the system requires equipment Cisco doesn't provide, they are able to give me advice on the equipment but won't give an official recommendation on the additional equipment.
I have worked on a separate project where we had to integrate existing cameras, speakers and microphones with a Webex Room Bar Pro using a Crestron room controller.  Once the codec was connected to the controller, the installer used the audio console on the codec to fine-tune the settings.  Since feedback, audio gain, etc., has to be managed when you integrate multiple systems and that's not my forte, we worked together to manage the settings.  Be sure to make a back up as soon as you have the settings tested as well.
You might find the link below helpful as well:
https://www.webex.com/us/en/workspaces.html
Response Signature
