Room Bookings and RoomOS 11
RaulanG
Hi all,
Just wondering if anyone has noticed that with room bookings with the in-room controller/navigator with RoomOS 11 there is no longer an option to use that device to book the room?
Pressing the Calendar button - just shows the availability of the room, but can't book it
While the dedicated Room Navigator outside of the room is still functional and still can be used to book the room.
I've tried to enable and disable the in-room booking option for the device - but as of yet, no luck
Hi @RaulanG
I am running Room OS 11 beta (RoomOS 11.0.0.l4t-22 51f1efb3842) on my Cisco Desk with Room Booking turned on (like in your screen shots) and I am able to book the device from the touch screen. See picture below...
willalex
Hi Raulan,
The room booking feature is still in beta, but is planned to be available when RoomOS 11 goes into Stable. If you'd like to try it out beforehand, you can apply to join the beta program at beta.webex.com. Thank you.
