I've read that when registering a DX80 to WebEx/Spark, you lose access to the web GUI interface to make it streamlined and simple. Even after a factory reset, you cannot login to the web GUI anymore. I have almost no options to configure the device at settings.webex.com, other than the name of the device. I am trying to use the device as a walk-up kiosk for a remote site during COIVD, is there a way to at least set it to auto-answer calls? Is there another website I can go to find more settings?
Thanks!
