TelePresence MX700 moving
TelePresence MX700
We need some Gidance to move a TelePresence MX700 to another building. Things to consider... Calibration... Disconection... Dismounting....
Derek Payne
Is the MX700 Wall Mounted, floor standing/wall secured, or floor standing/on-skis?
If it's got the floor stand on it, this can be done using a furniture dolly and 3 people to walk with the system.    Just be sure to lift the system onto the furniture dolly and not to try to lever it up one end at a time, else you'll bend the frame.
Video Conferencing since before it was cool or cost effective.
THANKS!!! (a lot!!!)
We do have a Rol-a-Lift (dolly) and as you said directions clearly say we have to make a coordinated (both at the same time).
Best Regards
