02-15-2025 09:11 AM
Bonjour, je suis actuelement a la recherche d'un visiophone compatible webex, pour le but de pouvoir passer las appels des clients qui viens visiter notre societé vers les smartphones de nos collaborateurs sur appliquation webex qu'on utilise deja. Ce visiophone sera posé a l'entrée et toute personne souhaitant de parler en visio avec l'interlocuteur avec smartpon webex pourra l'utiliser. Pouvez vous me conceiller un model de visiophone ou une societe qui pourra l'installer et configurer. Nous avons besoins de plusieurs visiophones, le premier doit etre installé et configuré a Velizy Villacoublay 78140.
Merci
02-25-2025 08:46 AM
@vadim78140 You can consider the Cisco Desk Series (such as the Cisco Desk Pro or Cisco Desk Camera with a compatible device) or the Cisco Webex Room Phone, which supports Webex integration and video calls. Another option is 2N IP Style or Akuvox R29, both of which are high-quality video intercoms that support SIP and can be integrated with Webex via a compatible gateway.
For installation and configuration in Vélizy-Villacoublay (78140), I recommend reaching out to Cisco partners or specialized AV and intercom system integrators in your area. You can find local Cisco-certified resellers and service providers through the Cisco Partner Locator on Cisco's website. Let me know if you need help narrowing down specific vendors!
02-19-2025 06:37 PM
You would probably be best served by contacting one of the local Cisco Partners in France who should be able to assist you to specify, source, install and configure the device for you.
The Partner Locator (cisco.com) tool should help you find one.
Please remember to mark helpful responses and to set your question as answered if appropriate.
02-17-2025 06:57 AM
thanks for the answer. in my case i need an external videophone so that an unknown person coming to the door could talk with it by pressing one button. and this videophone sent a call to one of the smartphones with webex installed
02-17-2025 06:12 AM
reference this guide. Supported devices for Webex Calling
2N has some great video phones. You can also repurpose a Cisco Webex Deskpro and enable kiosk mode. RoomOS for Collab Devices
