Webex Activation Code - Verify Your Internet Connection
4738EX9
Community Member
I'm having a issue with getting my activation code to work with my desk phone. When I click continue after entering my code, I get this message (Verify Your Internet Connection). Currently my team is trying to get webex calling working and want to use desk phones as well as the soft-phone in webex. Currently my coworker's phone is working and we swapped accounts/codes as mine was not working and mine in turn worked for him and his still showed the same error. We have the exact same ISP with exact same firewall/network settings on the modem. The error the phone is throwing out is
Address resolution failure: gds.huron-dev.com
My phone is a cisco CP-8811-K9 V11 and my coworkers is V04 of the same phone. We are both unable to ping the above domain from either corporate or home networks.
Any suggestions are appreciated. I am not a VOIP guy at all, so my knowledge is extremely limited.
Thank you
4738EX9
Community Member
I found the solution for my issue!
I had to upgrade the code on the phone from Enterprise version to Wedex version on the phone itself.
Code-based activation
  1. Press the Applications button
      and select Admin Settings -> Network/Ethernet Setup -> IPv4 Setup
  2. Set Alternate TFTP to On/Yes and configure TFTP Server 1 to 3.14.211.49
  3. Select Apply
  4. Select Erase when prompted that a Trust List is installed on the phone.
https://www.cisco.com/c/en/us/support/docs/smb/collaboration-endpoints/cisco-ip-phone-8800-series/kmgmt-3441-convert-enterprise-phone-for-webex-calling.html
4738EX9
Community Member
  3. Select Apply
c0a4
Frequent Visitor
Frequent Visitor
I have this same issue!
