Wireless Screen Sharing
Matt_W
Level 8
Level 8
Where did the setting to enable direct screen sharing from windows move to in a room kit's settings?  I know I can enable screen share from the share.webex.com, or by using the built in wireless screen share in the Webex App.  However, there used to be a setting that allowed the "connect to a wireless display" option that is built directly into windows.  It was a while since I went looking for it but now I can't seem to find it.  I do remember that this feature did need to be enabled in the devices setting and then when using it you needed to input the code off the screen.
0 Replies 0
