Create integration belongs to int environment
ashishsi@cisco.com
I am trying to create an integration app to test with int environment, How can we do that?
the basis issue here is for the authentication in int environment it should redirect to idbrokerbts.webex.com as the CI token for the user can be generated from there as users belong to this place only.
Please let me know how to create an integration with int environment.
-Ashish
Raffaele Lagana
We don't really use the INT environment within our Dev Support team, I think that's only used by internal Cisco Engineering teams. Usually, with the prod dev portal, you simply go to https://developer.webex.com/my-apps/new and create an integration from there, then you can get the OAuth URL from there and start the auth flow. But not sure whether it's the same in the int environment. I would suggest to check with whoever provided you access to the int environment, this community is mainly for the publicly available dev portal, APIs, etc.
ashishsi@cisco.com
Thank you...
Raffaele Lagana
