04-13-2022 02:09 AM
Solved! Go to Solution.
04-13-2022 02:11 AM
I believe you should be able to update a user's site and licenses through the /people API using a full admin from the same org. Note that both the current site and the site you want to move the user to would need to be under the same org. If you are trying to move the user to another org, this API will not allow same.
04-13-2022 02:11 AM
