guest issuer use of cards
Raffaele Lagana
Hi there, I’ve read the limitations of a guest issuer, I looks like that cards are possible for guest issuer. Is that correct?
Raffaele Lagana
if you mean a guest issuer created user sending cards through the /messages API then yes, that's possible. You just need to ensure that you exchange the JWT for an access token that can be used with the API.
Raffaele Lagana
