Inactive Users in Webex Contact center Admin hub
bino.thomas
Can someone explain why the deleted users are still appearing in  the user list as inactive users under Webex Contact Center Admin Dash?
These users have left the company and I had deleted them 2 months ago.
Thank you very much Rudrakshi.
We are not using Directory connectors so we will contact TAC.
Rudrakshi
Are you using Directory Connector to populate users in Webex Control Hub?  If so, then are 2 scenarios for inactive user:
  • If user accounts have been disabled in Active Directory they'll be marked inactive in Webex Control Hub and will remain that way
  • If user account have been deleted from Active Directory, they will be marked inactive and then deleted after 7 days.
For more information on the above, you may read Recover Accidentally Deleted Users section under the Deployment Guide for Directory Connector available here.
If you are not using Directory Connector for directory synchronization in your organization, I would recommend you to reach out to the TAC - help.webex.com/contact. I hope that may help!
Best regards,
Rudrakshi Srivastava
